Flushing AC System
why do you wish to flush your a/c systems. did your compresser blow up? post more details.
K series on crack
Street Car on 25PSI V V V V V V
http://www.youtube.com/watch?v=_sn1WsbI0UQ
S D M
K series on crack
S D M
i have a qurestion so ill rephrase his question
how do u get your ac ice cold lol, do u have to flush it or just buy those can things
The Myspace Page
Hero's arent born there american
made.
Aco. 53rd CSB LTF - TMT - 1st SQD
Afganistan Tour 2005 - 2006
- Its Game Time -
The Myspace Page
made.
- Its Game Time -
Gators Bitches!
on
see i was told to flush it to get all the dirt and $hit out to make it cold....cause I bought a can of r132 or r134 whatever it was...and it didnt help. Someone told me to flush the system and then charge it again. So I want to charge it.
your a/c is a closed system. if dirt can get in then the freon is all ready gone. its obvious your not very knowledgeable in this area so i dont recomend you do anything else. you can only do more harm than good. there is a large number of things that can cause an a/c system to blow warm or not freezing cold. w/ out a/c pressures i cant help you on the computer.adding freon is not all ways the answer. you also need to know the amount you have in the system as well as how much you are adding. to much freon= no cold . to little freon = no cold
K series on crack
S D M
K series on crack
S D M
yah me that means if i add one more can my ac will be colder. yes i ihave one of those gauges things its still in red though
The Myspace Page
made.
- Its Game Time -
The Myspace Page
made.
- Its Game Time -
Gators Bitches!
on
so after you put the engine in did you evacuate the system? that means hooking up a vacume pump and leaving in a vacume for 15-20 min to remove air and moisture. if this is not done it could cause problems. if you expect help you need to fully explaine your problem for someone to help.
K series on crack
S D M
K series on crack
S D M
Flush is the wrong terminology. Evacuating the system is the correct term. This is done with a good vacuum pump. Pump 'er down and pulling a good vacuum will suck all the shit and mositure (shit) from the system. Replacing whatever the system uses for a drier \ filter would be prudent.
