rear disc conversion ??
will the rear disc setup of a eg 92-95 work on a ef 88-91. mainly the 90-91 cause i know there is some difference in the rear lower control arms of a 88-89 as opposed to that of a 90-91. also i know that crx si's had the all around discs, didn't civic hatches si's come like that also? thanks.
you can use the trailing arm off of any 90+civic/crx with rear disks or any 90+ teg. Use the ebrake cables off a 90-93 teg, I got a set that I have no use for. Use the rear adjustment arm off your car and rear lca's also.
90-91 si hatches did not come with rear disks.
92-95 I believe some or all did. Might just be the ones with abs.
why did you post to the top? You got the answer to your question.
"What shitty poorly fitted aero did you ziptie on today, after installing shitty knockoff parts that dont fit worth a damn, followed up by poorly fitted cheap heavy wheels with the wrong offset so they rub but you play it off as looking cool, and then post pics here today"
