hondata launch control
Old Jun 25, 2004 | 08:16 AM
NChatch's Avatar
i stepped on my weiner!
i have it on my uberdata, but im not sure if it is the same as the hondata.
uberdata uses the VSS to make sure you arent moving and when you are stopped, you can use it.
we had a problem with it at first........it was too low, i had to raise it 5000rpms because it kept bogging with the turbo.... so i dont know if hondata will ask you what you want on there, but if it is wrong will you have to send your ecu back or take it somewhere and have it re done, will you have to pay again??
Top Dead Center Performance
Mobile Alabama 251 661 6067
owner/operator
www.tdcperformance.net
Old Jun 25, 2004 | 08:41 AM
Punkinterviews's Avatar
Chavez Motorsports
Yes, it'll have to be taken back to the tuner to be redone! This is what I like about the Zdyne I'm converting to, you have launch control set, try it if it doesn't work, turn to the laptop next to you plugged into the ECU change it, hit save and in less that 30 seconds you have changed the launch RPM and have saved it and are ready to try it, versus pulling the chip, re programming it and the re installing it. But my big concern would be who's gonna do your Hondata work now that John's gone?
Chavez Motorsports
The reason CMS fabrication is closed!! Click me!
11.965 @ 114 Supercharged Teg...RIP
