code questions
Old Jun 18, 2004 | 08:33 PM
DaBman's Avatar
Default code questions
My ecu is throwing codes 12 and 43... what could be causing the code 43 and how do i fix it. Its a 94 h23.
Thanks.
Old Jun 19, 2004 | 03:01 AM
mtber's Avatar
IAT Sensor (Intake Air Temperature)
defective circuit or unplugged / defective sensor
43
Fuel Supply System
defective or malfunctioning fuel supply system
Old Jun 19, 2004 | 05:57 AM
DaBman's Avatar
I thought 12 was egr valve?
Old Jun 19, 2004 | 08:14 PM
mtber's Avatar
Read my sig.
Old Jun 19, 2004 | 11:23 PM
rangcrx's Avatar
engine building &best
it means Exhaust Gas Recirculation more then likely it is bad,check all vaccum lines and you map sensor
Old Jun 19, 2004 | 11:24 PM
rangcrx's Avatar
im guessing checkengine light is on?
Old Jun 20, 2004 | 08:29 AM
DaBman's Avatar
yea.. the light is on... the vacuum lines are hooked up and the egr is connected.
