This thing worth a damn?
Gauge-Type Wideband UEGO Controller
AEM’s Wideband UEGO Controller is also available in a gauge that includes a single-channel analog output with a Bosch O2 sensor in one unit!
AEM’s Gauge-Type Wideband UEGO Controller features an LED readout and sweeping LED “needle” that changes colors as AFR changes from rich to lean. The unit’s 52mm (2-1/16”) gauge housing fits in most gauge pods and can be remotely mounted virtually anywhere. No laptop required for monitoring!
Key Features:
Bosch sensor included!
24 Color-coded LED display lights provide immediate reference to engine’s air/fuel ratio (AFR) or Lambda
Integrated three-digit display reveals AFR or Lambda in real time
User-programmable 0-5v analog output included for use with data loggers and ANY engine management system
Ideal AFR monitoring tool for carbureted applications and engine dynamometers
Does not oscillate AFR like narrow band sensors
Serial data stream included for output of AFR (RS 232)
Accurate to 0.1 AFR
Key Features:
Accurate to 0.1 AFR
what's your input?
It is a wideband o2 sensor ofcourse its worth a dam
are you fucking kidding bro
A wideband is like the best investment you can EVER make !!!!
Project WHIPLASH has begun!!!
InductionPerformance.com
NS Racing (813)842-5517
