stupid piece of honda!!!!!**OVERHEATING**
Old Jun 14, 2004 | 12:08 PM
spoonfed's Avatar
Tha numba one stunna
... content in sig not work friendly
Old Jun 14, 2004 | 02:25 PM
CamaroJoe's Avatar
Landscape Engineer
Sounds like for whatever reason your water pump isn't pumping the water good enough. Do you have an underdrive crank pully? If so, your water pump may not be getting enough power to sufficiently cool the engine, especially at low RPMs. Another possibility is that there is a clog somewhere in your cooling system. That would dramatically decrease the effectiveness of your water pump.
-Joe
Old Jun 14, 2004 | 02:45 PM
1QWKCRX's Avatar
That CRX Guy
It doesn't sound like a water pump issue. If it's not in the red
while you are driving and in the red when you sit that is
due to the fact that your fans are not working and cooling the engine.
When in motion , you have outside air, but at a light, heat
builds up inside the bay with no way to cool off.
The other issue is that you should check your coolant for oil.
You may have blown a head gasket due to so much over heating and possibly warping your head.
Florida CRX Meet 2011 http://www.facebook.com/pages/Florid...2354313?ref=ts
Old Jun 14, 2004 | 05:24 PM
CamaroJoe's Avatar
Landscape Engineer
If it were a headgasket, I would imagine he would leak water either into the oil or the cylinder but he said the water is always full. Still, it would be a good idea to check the coolant for oil.
-Joe
Old Jun 15, 2004 | 03:54 AM
art's Avatar
art
E=MC-hammer
(govenator voice)it's DA PUMP SO PUMP IT UP!!!!!.........bitch
dont feel bad its a single cam you can have that bitch done in like 15min and still have time yank a load off.....
art
IM IN VA BITCH!!!!!!
www.rccustomz.com
Old Jun 16, 2004 | 02:18 PM
  #17 (permalink)
Josh's Avatar
Dr. Doom
you have a hondead, self explanatory.
Old Jun 16, 2004 | 04:33 PM
  #18 (permalink)
spoonfed's Avatar
god I can't wait to get both of my hon duhs...they both should be gone within the next two months if everything goes right
Old Jun 16, 2004 | 05:33 PM
  #19 (permalink)
RyanCivic2000's Avatar
Fuck the DOHC
Originally posted by Cronic
headgasket is my assumption.
I agree. Check the coolant reservoir for any signs of oil.
BTW, those of you who are saying to take the thermostat out or have the fan wired on all the time, that's ridiculous. There is no reason for the fan to be on while you're doing 70mph down the highway.
-00 Civic EX Coupe BUILT D16Y8, Precision SC50, 12.80@105.8 14psi
-00 Chevrolet S10 LS 4.3L V6 Gas Guzzler
http://www.Sohchonda.com
Honda SOHC & D Series Resource
Old Jun 16, 2004 | 08:52 PM
  #20 (permalink)
Josh's Avatar
Dr. Doom
what are you giving the hatch away for
