engine swap for a 93 prelude
Old Jun 7, 2004 | 02:51 PM
CrAzyLuDeGiRl's Avatar
New Member
Default engine swap for a 93 prelude
Hey there.
I have a h23a engine in my 93 prelude I was wondering if they make this in vtec or not. Also if i got a h22 what would i need to up grade on my car. would i need a new suspension or a different tranmission. what other things might i need
thanks
♥ (¯*·.¸(¯*·.Kat.·*¯)¸.·*¯) ♥
Old Jun 7, 2004 | 02:56 PM
InsaneCivicCoupe's Avatar
Retired Ricer...
Just get an H22 complete swap from the 92-95 Lude and a vtec jumper harness and you'll be all set....
Project WHIPLASH has begun!!!
InductionPerformance.com
NS Racing (813)842-5517
Old Jun 7, 2004 | 03:01 PM
Vito_Corleone's Avatar
TR Balla Donor Supreme
Search. Seriously, these questions are really newbish, just look in the FAQ, search in here, and run a search on Google, THEN come back and ask us questions.
Old Jun 7, 2004 | 03:50 PM
blurboEK's Avatar
proud father ;D
93 prelude is pre-wired for VTEC. Purchase a complete h22 (from 93-95) Your suspension will be fine, may want to upgrade front brakes. The block/transmission casting on both the H22 and H23 are the same so your mounts/axles will work. You can purchase a long-block for around $1000 and use your current transmission or you can purchase a full swap for around $2000 (which is highly recommended). This is by far one of the easiest swaps! Motor drops right in, use your current harness, shift linkage. Replace ecu with P13 ecu, add VTEC pressure switch and solenoid valve and your set. PM me if your interested in a motor or motor+install ...
-Mike
http://www.myspace.com/jdmmike02
2000 Ford Expedition Eddie Bauer
2004 Kawasaki ZX6R - SOLD
