Golden Eagle Vtec Conversion Kit..
Does anyone know about this kit? I was intrested in this instead of machining the block for this?
I might I might not. Wondering what you guys thought about this. Looks very simple and makes sense.
Here is a link to what iam talking about..
http://www.goldeneaglemfg.com/street.html
I might I might not. Wondering what you guys thought about this. Looks very simple and makes sense. Here is a link to what iam talking about..
I am running the GE setup on my car. The kit is about $130 shipped MSRP.
You can get them for 99 shipped if you look around. I'm running a block with a crack at the oil pressure sender so I had to weld it shut and run the golden eagle kit. Works pretty good.
Gracie Barra Clearwater
yeah deffinetley the way to go, i believe the hole should be drilled to a 14mm, and most machinist just use a 9/16 bit and the holes are just a cunt hair off which is the main reason for oil leak problems on an LS/vtec, or its the other way around, either way they are worth it,. i think you can get just the dowel pins for like 30.00 shipped
Top Dead Center Performance
Mobile Alabama 251 661 6067
owner/operator
www.tdcperformance.net
owner/operator
The GE OIL LINE KIT is what KJ & I were reffering to.
The GE DOWELS I have also used. They are good to use but they do require you to open your LS headgasket up to accept them
You will see, its not rocket science.
I personally use lightning motorsports they are good guys (google them)
