Tranny Probs.
Old May 27, 2004 | 08:04 AM
JDM-Civic-Coupe's Avatar
USAF
Default Tranny Probs.
Im having problems with a 98' tranny,. i shift into 2nd and it grinds and pops out immediatly. could it be the gear,synchrsnizer in 2nd or what, any info would be greatly appreciated and if you have a single cam tranny f/s PM me.Thanks,
-Chris
USAF
Old May 27, 2004 | 08:48 AM
NitrousAcid069's Avatar
4.6L Rice Eater
get gm syncromesh transmission fluid friction modified....its great stuff, works wonders....it could be the syncronizers or it could be the brass and bearings in the transmission being worn down....thats whats wrong with mine and it has the same symptoms as yours
Old May 27, 2004 | 09:23 AM
Si-R Trickey's Avatar
The most interesting man
Your synchros sound like they are wasted...
Old May 28, 2004 | 05:26 PM
SickOfAlltezzas's Avatar
ALUMINUM POLISHER
i had the same problem with 2nd gear for like 2-3 months...then it just stopped and never did it ever again
Originally Posted by 240Cyanide
TR's better anyways.. where else could you find all this variety of assholes, drug specialist, and pedo's? not on that gay dsm site!
Old May 28, 2004 | 05:58 PM
Trip's Avatar
Dramatic Lemur
Take a day off, pull the bitch out and crack it open. You will need 3 bottles HONDA MTF, and both axle seals. Once you get it open look at the gears, take the jacked up lookg one to Honda, and get another(there may be order time involved, arrange for other modes of transportation.) Put everything in the same way it came out. Shouldn't cost more than $75. That's the cheapest route.
"Never attribute to malice that which can be adequately explained by stupidity."
AIM: TurboedTrip
Old May 28, 2004 | 06:01 PM
Suspect's Avatar
Certified since '85
I had a third gear grind and got rid of it by adding some tranny fluid in................hasnt done it since
TR Hydroponics Abuser #36329
J a s o0o n: i need to get piss ass shit face fuck bag bitch ass drunk god damn
Old May 28, 2004 | 06:40 PM
TRD_Tc's Avatar
Using The Force Of N/A
change you fluid (or atleast add some). if that doesn't work you'll have to take it appart and see what's going on. make sure you get someone to help you out cause its not easy for 1 person (plus you'll need another car to go your auto part store and home). Good Luck.
Old May 28, 2004 | 07:02 PM
60-1EK's Avatar
Engineer at the source
Default Re: Tranny Probs.
-Chris
= Worn countershaft bearing. I have seen this many times. High probability that this is problem and the fix is normally around 50 max in parts.
JESUS SAVES
9.69@151 Street Car
JKOBD
Old May 29, 2004 | 10:47 PM
USAF
I just got this tranny and im returning it...It has new tranny fuild in it... all i need is a good single cam tranny..
USAF
Old Jul 11, 2008 | 11:23 AM
crazyhondab16's Avatar
pm'd you
