crx turbo project
Old May 25, 2004 | 08:49 AM
honda-kid88's Avatar
Default crx turbo project
I have a T28 turbo that I plan to install on my crx(stock).
All I have is the turbo and was wondering what all else I
will need and how much it will cost. If you have done this
before or know anything about this please lmk.
thanx
Old May 25, 2004 | 09:09 AM
98TRDCam's Avatar
iron lung
your gonna need a turbo manifold(hf,vx,or something else). adapter plate between turbo and manifold,downpipe, intercooler, boost controller(manual or electronic) blow off valve,wastegate if your turbo doesnt have one, oil lines, T's to tap oil,some blue top dsm injectors, misc piping etc . and depending what motor is in your car(1.5 or 1.6) you might have to do a mpi swap. also how many miles on the motor(might want to swap timing belt, head gasket, seals, oil & water pump, etc.
40ozCasualty's Avatar
shift_lock
http://www.homemadeturbo.com/
Old May 25, 2004 | 09:52 AM
pressuredsol's Avatar
Pleasure the do me
You do not ness need 450's. 310's would be enough for you.
Old May 25, 2004 | 10:08 AM
Pleasure the do me
That is why I say 310s and tune down. 450's are overkill.
Old May 25, 2004 | 11:02 AM
thanx for all the info.
does any one have all this stuff ?
Old May 25, 2004 | 02:15 PM
InsaneCivicCoupe's Avatar
Retired Ricer...
450s are just alot easier to find because they came stock in some cars... 310s are mostly aftermarket... I personally would just get some Prelude 290cc injectors....
Project WHIPLASH has begun!!!
InductionPerformance.com
NS Racing (813)842-5517
Old May 25, 2004 | 07:42 PM
Pleasure the do me
+1 about the lude injectors. Forgot about that.
Old May 25, 2004 | 08:51 PM
Janky99's Avatar
Honda Guru
Man, I've boosted my single cam, and if you don't have a really good budget, like if your tight on money and don't have much to do it. don't. because you are going to learn from experience. I learned the hard way, and I have about 4 blown D series motors just laying around. I can't stress how much not to cheap on fuel. I whent cheap and used an fmu, and fried rings like they were going out of style. I recommend 450's and a safc, which really isnt that expensive. If you hunt, you can get 450's for about 50 and an afc for 200. Just do not cut any corners now because you'll pay for it later. -Ben
