?Questions for the single cam guys?
Old May 23, 2004 | 08:26 AM
civicvxhatch's Avatar
Default ?Questions for the single cam guys?
I have a 92 hatch with a vx block and a z6 head. And was wondering if a z6 block or a y7 block would be better and if so which one. Because i heard the vx block has low compression pistons.
Old May 23, 2004 | 08:39 AM
TTT
Janky Crew Productions
Old May 23, 2004 | 09:05 AM
NitrousAcid069's Avatar
4.6L Rice Eater
a z6 head on a z6 block is just the ex motor. a y7 block might give you higher compression, but im not sure....ive never seen it done it personally. the vx does have lower compression pistons then the dx or ex. i would say if the setup your running right now is running well, then keep it like that. if you change the block, it may screw somehting up.
Old May 23, 2004 | 09:42 AM
Yea im trying to find more info about the y7 block so i can get a higher compression. Thanx for the reply
Old May 23, 2004 | 12:49 PM
MacGruber's Avatar
MaDe Of MoNeY
mill the head.
Originally Posted by Z28ricer
"What shitty poorly fitted aero did you ziptie on today, after installing shitty knockoff parts that dont fit worth a damn, followed up by poorly fitted cheap heavy wheels with the wrong offset so they rub but you play it off as looking cool, and then post pics here today"
Old May 23, 2004 | 12:58 PM
Rather not!
Old May 23, 2004 | 12:59 PM
RyanCivic2000's Avatar
Fuck the DOHC
Z6 pistons = more compression than the VX
Y7 pistons = more compression than the Z6
Y8 pistons = more compression than the Y7
This is a great resource.
http://www.knology.net/~jediklc/D.htm
-00 Civic EX Coupe BUILT D16Y8, Precision SC50, 12.80@105.8 14psi
-00 Chevrolet S10 LS 4.3L V6 Gas Guzzler
http://www.Sohchonda.com
Honda SOHC & D Series Resource
Old May 23, 2004 | 02:04 PM
Thanks
Old May 23, 2004 | 02:29 PM
MacGruber's Avatar
MaDe Of MoNeY
why not? or get a thinner head gasket.
Old May 23, 2004 | 03:15 PM
Maybe ill do that too.....
