interesting project.. 95 accord v6 auto, to manual?
is there any way this can be done, cause someone wants to trade me an automatic v6 accord for my b16a rex and its SOOOOOO clean, its one of the cleanest accords ive seen yet, and i was jus wondering if there is any way possible to swap in a 5spd to that car, or maybe even the new accord v6 6spd? lemme know how much that would be (an estimate, and then if it could even be done)
thanks again guys..
thanks again guys..
then engine in the 95-97 accord V6 was basically the same as the 86-89 legend...and they did come in a five speed. should bolt up but mounts may be another story.
Liar, you couldn't cut me deeper with a knife if you tried
I know more about lawnmowers than Hondas really, but the tranny will probably bolt in fine. Your big problems will come from the fact that they'll probably have to remove most of the brake system and cut a hole in your floor/firewall to install the clutch pedal. Also, you may need a console designed with a manual tranny in mind, as the shifters are probably completely different. As far as mounts go, they may have to fabricate their own and bolt it on, but that shouldn't be too big of a deal.
-Joe
-Joe
