V-tec Controller Wiring...
Old May 22, 2004 | 08:06 AM
YBlegal-1's Avatar
your honda sux
Default V-tec Controller Wiring...
I HAVE A FIELDS BOXER SERIES V-TEC CONTROLLER, AND IM TRYIN TO WIRE IT UP TO A 91 CRX SI ECU....CAN SUMBODY HELP ME WITH WICH WIRES GO WHERE? THANX, Troy
Old May 22, 2004 | 11:15 AM
mug's Avatar
mug
Hey Mr Toilet Im The Shit
http://www.vtec.net/articles/view-ar...page_number=10
Old May 22, 2004 | 11:30 AM
Vito_Corleone's Avatar
TR Balla Donor Supreme
OMG CHILL WITH THE CAPS!!!
Old May 23, 2004 | 06:19 AM
opiumdaze's Avatar
1) First, find the IGNITION POWER wire which is YELLOW/ BLACK, you will need to expose a 5-10mm portion of this wire to solder the RED wire from your SFC to. Do not cut this wire!.
2) Now find the RPM SIGNAL wire which is WHITE, once again, do not cut this wire, you need to tap into it by exposing the wire and making a solder join to the GREEN wire which comes from the SFC unit.
3) The first wire you need to cut is the VTEC SIGNAL wire which is GREEN/White. Make sure you leave enough wire on each side to join to. Make the cut and solder the end coming from the ecu to the YELLOW wire from the SFC, connect the other side of the GREEN/WHITE wire to the DARK BLUE wire from the SFC.
4) Find and cut the VTM wire which is colored BLUE/BLACK. Solder this to the GREEN/WHITE wire from your SFC. the other end of the VTM wire is not needed and must be insulated with tape.
5) Now find the SPEED SENSOR wire which is colored YELLOW/RED. Connect the end coming from the ECU to the PURPLE wire on the SFC and the remaining end to the LIGHT BLUE wire from the SFC.
6) Finally, cut the SENSOR LINE wire which is WHITE and solder the ORANGE wire from the SFC to the ECU end of the WHITE wire and the remaining end to the BROWN wire coming from your SFC unit.
Now that all the wiring is finished, you need to ground the unit and and reinstall the ECU. I found a bolt behind and to the left of the ECU to ground it to, it was the grounding point for another wire as well.
Replace the ECU and the metal panel, securing them with the 4 bolts.
Old May 23, 2004 | 06:20 AM
opiumdaze's Avatar
Old May 23, 2004 | 02:24 PM
j0shth3j3w's Avatar
Everything is for trade.
I thought I gave you the instructions....
Just text me.... 813-785-5222
