best rods for this..
Old May 20, 2004 | 12:41 PM
TSX24L's Avatar
Default best rods for this..
What would be the better choice on rods?
I have Endyn 12.5 high comp. std rod lenght pistons. 81.5mm. Its going in a 94 ls block. And should I use a block gaurd? Iam using a stock b16 head.
Old May 20, 2004 | 12:53 PM
24-7's Avatar
Civic Racing eXperiment
Default Re: best rods for this..
What are you planning on runnin' as far as power source?
Old May 20, 2004 | 12:58 PM
TSX24L's Avatar
what do you mean power source?
Old May 20, 2004 | 01:02 PM
24-7's Avatar
Nitrous,super charger, turbo, normally aspirated?
Old May 20, 2004 | 01:08 PM
TSX24L's Avatar
NA
TSX24L's Avatar
I want to get around 210-220whp.
Old May 20, 2004 | 01:42 PM
99B16Si's Avatar
crower, manley, pauter, carillo, etc will all get the job done but i would just go with eagles for half the price for your power goals. and youd be very lucky to get 210-220whp out of a 1.8 lsvtec
Old May 20, 2004 | 07:02 PM
mtber's Avatar
To make 210 plus WHP on a 81mm LS/VTEC is gonna be hard.
Aftermarket cams & good tuning will help you but what you really need is a 84mm setup to hit those numbers on pump gas with ease
Eagle rods will work just fine. Make sure you purchase rods to the spec of your r/s ratio i.e. ls eagle rods if your using an ls crank etc.
Old May 21, 2004 | 07:04 AM
99B16Si's Avatar
Originally posted by `92CXhatch
do you really think that compression would be anything other than NA???
-Keith
nitrous and high compression get along pretty well with good tuning
