Need Helms for 88 crx or wiring help.
Old May 17, 2004 | 04:30 PM
j0shth3j3w's Avatar
Everything is for trade.
Default Need Helms for 88 crx or wiring help.
I need a wiring diagram for the 88, 89, or 91 crx gauge cluster with a tach. One of the clusters is from a 89 DX and the other is from a 91 SI. I have a 88 crx and the cluster ground was burnt so I got a 91 si and a 89 dx but niether are working. I attempted to repin the clips but the conversion diagram I have is for the non-tach 90 dx so it was wrong. Then when I re-pined it back nothing but the speedo, turn signal, and bright lights indicator work. So I need a helms manual or the schematics for the clusters and wiring. Or someone who has done this before.
Thanks in advance....
Just text me.... 813-785-5222
Old May 17, 2004 | 04:33 PM
MacGruber's Avatar
MaDe Of MoNeY
It should have been plug and play. I have a haynes but it sucks ass and I dont have a scanner
Originally Posted by Z28ricer
"What shitty poorly fitted aero did you ziptie on today, after installing shitty knockoff parts that dont fit worth a damn, followed up by poorly fitted cheap heavy wheels with the wrong offset so they rub but you play it off as looking cool, and then post pics here today"
Old May 17, 2004 | 04:38 PM
j0shth3j3w's Avatar
I have the haynes but I didn't see the cluster diagram in it.
Old May 17, 2004 | 07:08 PM
kender's Avatar
gadget man
it is plug and play if you mean you can plug it in and play with everything till you get it right. there are several wires that need to be swapped around within each plug and there are 2 wires, 1 from each plug, that need to be swapped from 1 plug to the other. I will try to see if I can find the notes from my swap but I looked at the circuit path and traced it by hand to see where each one goes and drew up my own pin out diagram for both clusters then swapped the pins to where they needed to be.
this can be a hard way to go if you don't understand electronics and electrical flow, given that there are several indicator lights that have a common connection and then seperate triggers as well as a few diodes in the set up.
U.S.S.A Crew Member #001
Old May 18, 2004 | 02:55 AM
MacGruber's Avatar
MaDe Of MoNeY
I have a 1989 honda dx and I swaped a honda crx hf gauge cluster(with tach) into my car and everything works.
Old May 18, 2004 | 05:01 AM
j0shth3j3w's Avatar
mikecivichb:
Do me a favor Mike take your cluster out and write the wire colors down for me. The plugs read if your looking at the plug from the side that enters into the cluster the non-wire side (B12-B1) on the left and on the right (A8-A1).
kender:
I hope you can find that it would help a lot. Also what cluster do you have in your car? If you could tell me your wire set up now meaning the same like I asked Mike maybe I could do it the same.
Thanks either way.....
Old May 18, 2004 | 10:54 AM
MacGruber's Avatar
MaDe Of MoNeY
I cant do It today but Ill do It tomorrow and ill post it up if thats ok with you. I have to get ready for work. Ill defentaly post it up unless you want to meet tomorrow at tampa lanes. The same spot we met before and you can look for your self. If not Ill post it up tomorrow
Old May 18, 2004 | 11:47 AM
j0shth3j3w's Avatar
Good looking out Cronic.....
Maybe call me first tonight if you can or maybe you can make the trip to my house so we can hang out in the shade and take our time...
Old May 18, 2004 | 01:07 PM
MacGruber's Avatar
MaDe Of MoNeY
pm me your number i dont have it any more thanks. I get off at 9:30pm we can do it sometime after. Or if you want I can drive out there tomorrow and chill till 12:00pm
