100A Battery fuse keeps blowing
Old May 16, 2004 | 10:53 AM
SilverTegra's Avatar
Default 100A Battery fuse keeps blowing
I just installed a fresh ls/vtec motor in the 96 integra. I went to connect the battery cables and pop goes the 100A battery fuse. I tried installing another but it popped also. So I have a major short somewhere, how the hell do I go about finding it. My 02 sensor wiring is disconnected along with my coolent temp sensor on the head, maybe this has something to do with it? I also degreased the engine bay while the motor was out, I doubt it but could this have screwed up my harness?
Old May 16, 2004 | 11:06 AM
Josh's Avatar
Dr. Doom
i would just start OHM'ing out connections. also, liquids can sometimes cause a short by acting as a "bridge" between connections, therefore shorting the circuit, i would allow everything to dry out before trying to replace it again. finally, i would check all my grounds for poor connections, lose wires, and sufficient surface area to ground the connection at.
Old May 17, 2004 | 07:20 PM
kender's Avatar
gadget man
U.S.S.A Crew Member #001
