b16 wiring
Old May 9, 2004 | 08:54 PM
91b16si's Avatar
Default b16 wiring
i have a friend who just got a b16a1 put into his 89 crx dx and he has it all hooked up and its running and vtec is hooked up but the ecu is throwing a code 4 witch is crank angle sensor so it wont rev past 3500 and hes fed up with switching out dizzys and screwing around with it and wants to pay some one to do it so let me know if you guys know someone who can fix it
Old May 9, 2004 | 09:00 PM
rangcrx's Avatar
engine building &best
just use a crx si distributor thats all i did when i got the code alot cheapper to buy brand new
i love AUTOZONE
Old May 10, 2004 | 07:21 PM
91b16si's Avatar
did didnt help anyone know who can fix the problem he has two hundred to the first person who can fix it
BFK for life, forever, get your dick sucked
Old May 11, 2004 | 10:27 AM
91b16si's Avatar
Old May 11, 2004 | 11:36 AM
TSX24L's Avatar
what about the pins in the ecu are they hooked up correctly? Trace your wiring. That was my problem when i had a crx b16. Good luck thats a clean swap you guys did.
Old May 11, 2004 | 11:54 AM
91b16si's Avatar
ya we tested the pins, oh and thanx on the swap thats my hatch you saw, that one is running fine and hitting vtec just like it should and the wiring on my friends crx is wired the same so i dont understand but well figure it out
Old May 11, 2004 | 07:06 PM
liface105's Avatar
hey i had the same problem in my 91 civic when i put a ls in it. all it was was the crankangle sensor was not touching the ecu. i made them touch and it did the trick.
