Quick question???
Old May 9, 2004 | 08:30 PM
Crab Cakes's Avatar
So Lost!
Default Quick question???
what would the compression be if i put type r
pistons in a gsr???
thanks, george
Old May 9, 2004 | 08:36 PM
mtber's Avatar
USDM or JDM type-r pistons ?
JDM type-r pistons in a b18c1: 11.3:1
USDM type-r pistons in a b18c1: 10.8:1
These specs are with a 3 oem layer headgasket.
Check the specs your self:
http://www.c-speedracing.com/howto/c...c/compcalc.php
Old May 9, 2004 | 08:50 PM
Crab Cakes's Avatar
So Lost!
thanks...
Im The Original Crab!
Old May 9, 2004 | 08:52 PM
InsaneCivicCoupe's Avatar
Retired Ricer...
what about if you were to do it with a tester.... how do you convert it????
say for example, a compression test on a gsr came back 235 accross the board.... that would be???
Project WHIPLASH has begun!!!
InductionPerformance.com
NS Racing (813)842-5517
Old May 9, 2004 | 08:58 PM
99B16Si's Avatar
u cant really go by that to determine the compression ratio. static compression is going to vary
Old May 9, 2004 | 09:01 PM
Crab Cakes's Avatar
So Lost!
so how could we determine the comp ratio, dave???
Old May 9, 2004 | 09:17 PM
mtber's Avatar
You determin the compression ratio you should achieve with certain components via knowing the components inside the motor. There are other ways to determin compression but I wont get into that.
Old May 9, 2004 | 11:12 PM
mtber's Avatar
I found a nice write up & mirrored it to be able to explain it in "honda terms".
http://phearable.net/tech/cr
Basically find all your specs & use a calculator & or formulas.
http://www.race-cars.net/calculators...alculator.html
