b20 swap
Old May 8, 2004 | 10:54 PM
mtber's Avatar
Originally posted by sl0 t3g
he asked where he could find them, no one ever said he NEEDED them.
Hey big boy his 1st post said:
"do i need a b20 computer and what kind of axels, and mounts"
Then InsaneCivicSedan recommended hasport mounts for some odd reason. I agree they are good mounts but they are overkill on an OEM b20 swap.
Hence my reply of: Why would he need a hasport mount kit ?
As you can see he didn't know he could use OEM motor mounts.
Old May 8, 2004 | 10:58 PM
mtber's Avatar
Originally posted by YBlegal
so just use the stock mounts, minus the rear tranny mount and for that just use a 99-00 SI rear mount? and as far as the axels go, will any B-series axels work with any B-series tranny? and also will they all work with my spindals, as far as the splines go? and for the wiring the IACV is the only thing needed to be rewired? and will a LS or b20 ECU just plug into my Factory harness? if so, would it be better to convert it to OBD1? thanx for all the info everyone...
Yes that is correct, use all OEM mounts & a 99-00 civic si rear lower mount bracket. Also to retain A/C use a 94-95 DOHC vtec delsol ac bracket.
Depending on what b20 motor you have, you may need a different intake manifold, but that will be obvious by looking at your motor.
Any 94-01 integra or 99-00 civic si axles will work, they are all the same part number at NAPA.
Concerning your ecu a obd1 ecu with a obd2a to obd1 conversion harness will work or obd2a p75 computer will work etc...
Btw, I hope you know you need a bseries tranny i.e. ls or b16 tranny etc..
Check out some helpfull links I have on the site in my signature.
Old May 9, 2004 | 12:17 AM
InsaneCivicCoupe's Avatar
Retired Ricer...
If he plans to make any kind of power in the future I say better to do it now because once the motor is in its a pain in the ass to change mounts... Im goin through it now wishing i wouldve just got hasports to start with, its a matter of opinion i guess....
Project WHIPLASH has begun!!!
InductionPerformance.com
NS Racing (813)842-5517
Old May 9, 2004 | 12:30 AM
mtber's Avatar
Changing mounts is not that big of a deal with the proper tools i.e. air tools & jacks etc.
Running hasport mounts all the way around will make his car feel like a vibrator
If he plans on making a lot of power with the b20, he will more then likely have to pull the motor out for internal modifications.
At this time he could then install aftermarket mounts with ease if needed.
I am trying to save him money & fustrations from a vibrating cabin etc...
A rear 99-00 si lower mount is about $50-60.
He would need this mount regardless if he went with the hasport kit or not.
An ac bracket from a 94-95 dohc vtec delsol is $100-110 this mount would be required to retain the civic a/c compressor.
Old May 9, 2004 | 12:37 AM
Retired Ricer...
Yes this is true but you have to admit, it would be alot of fun to take a chick for a ride in a vibrating car....
Like I said, I was just stating personal opinion for if he had the extra money to play with....
Old May 9, 2004 | 05:58 AM
Josh's Avatar
Dr. Doom
look man, i wasn't trying to be a dick, back off. he just asked a question, and i answered it. no reason to be so smug.
Old May 9, 2004 | 09:06 AM
  #17 (permalink)
YBlegal-1's Avatar
your honda sux
yes i know i have to use a b-series tranny....and as far as the A/C goes, i yanked all that out when i first got the car this car is extremly gutted.....its a 4door, no backseats or brackets for them. no back dash no noise dampener, no carpet no door panels in the rear, no seat belt brackets...onley thing in the back besides the body of the car is a rear strut bar...engine bay is as minimal as possibly....no a/c no p/s...but anyways...i thank all of you for your info and opinions....ill prolly just use the stock mounts....oh and by the way i dont have the motor yet...where can i find one cheap, or at a decent price?
Old Jun 20, 2004 | 07:40 PM
  #18 (permalink)
97BLACKciVIC's Avatar
TR Balla Donor Supreme
Sorry if inturupted you guys conversaion but i thought i would put my word in.i did an ls swap into my 97 civic and my mounts r just find. the rear mount was 58 dollars from the honda dealer. The driver side monuts it just fine. i havent had any problems. and i know that this might be outside of the subject and all the question but if u have lowering spring or coilovers u might want to plan on lifting it up cuz i learn the hard way and ripped a big hole in my oil pan because of some dibre that was on the crosstown from all the consruction.
Old Jun 20, 2004 | 08:45 PM
  #19 (permalink)
MacGruber's Avatar
MaDe Of MoNeY
Trust me you didn't interrupt the conversation. Do you know why you didn't interrupt the conversation? BECAUSE IT ENDED MORE THAN A MONTH AGO.
Originally Posted by Z28ricer
"What shitty poorly fitted aero did you ziptie on today, after installing shitty knockoff parts that dont fit worth a damn, followed up by poorly fitted cheap heavy wheels with the wrong offset so they rub but you play it off as looking cool, and then post pics here today"
