d16y7
the d16y7 block is non v-tec right? so to put a z6(v-tec) head on it i would have to get a v-tec conversion kit for the block, a new head gasket, and a v-tec ecu right? do i need any new plug wires or anything?...what else do i need if anything?
thanks alot
thanks alot
ahh the mini-me swap
parts needed:
D16Z6 Cylinder Head (Including distributor cap, valve cover, plugs/wires, VTEC solenoid, etc)
D16Z6 or D16Y8 Head Gasket
P28 ECU
D16Z6 Timing Belt
Wire and plug for VTEC oil pressure switch
optional:
D16Z6 Intake Manifold
D16Z6 Exhaust Manifold
... if you remove your manifolds... you will need new head gaskets
also recommended:
NEW OEM-
Water Pump (for the block you are using)
Spark Plugs (HX D16Y5)
Spark Plug Wires
Valve Cover Gasket
Distributor cap and rotor
heres a good start
http://www.honda-tech.com/zerothread?id=554053
parts needed:
P28 ECU
D16Z6 Timing Belt
optional:
also recommended:
NEW OEM-
Spark Plug Wires
Valve Cover Gasket
heres a good start
2004 Blue Sapphire Sentra SE-R SpecV
