anyone have a UBERDATA turbo B16 base map???
Old Apr 27, 2004 | 12:44 PM
NChatch's Avatar
i stepped on my weiner!
Default anyone have a UBERDATA turbo B16 base map???
hey anyone out there have a turbo base map for uberdata, or if vertigo could help me out here, my buddies B16 turbo is now powered by uberdata but we dont know what to set all the factors and shit at, and dont want to blow the shit up.................someone give me a hand here
Top Dead Center Performance
Mobile Alabama 251 661 6067
owner/operator
www.tdcperformance.net
Old Apr 27, 2004 | 02:51 PM
BitbyStreetRacin's Avatar
once your bit, your done.
Blake (VeRTiGo) is definately the man to talk to about anything related to uberdata.
Would the B16 use the same .bin as the gsr.bin? Or must you make a whole new .bin specifically for the b16? I guess the only difference is the .2L....Im still learning about uberdata myself so I cant really help.....
Old Apr 27, 2004 | 03:51 PM
NChatch's Avatar
i dont know, he is going to be using the p28 from an EX so im not sure, the gsr would probably have a better base map, but since he is going to alter the thing completely i guess nay will do, i just wanted to get some figures from some people who have it so we can get his finished
owner/operator
Old Apr 27, 2004 | 04:19 PM
smoke3's Avatar
Its a secret
maybe u should search on uberdata forum on how to tune. its pretty simple u need a wideband thought. but settin the vaules on the program are pretty simple.
The Myspace Page
Hero's arent born there american
made.
Aco. 53rd CSB LTF - TMT - 1st SQD
Afganistan Tour 2005 - 2006
- Its Game Time -
Old Apr 27, 2004 | 05:01 PM
KJ's Avatar
KJ
bored at work
it really isn't that hard to generate a base map.
-Open the stock p30 file
-select the map sensor you have
-set the boost efficiency to about 100%
-set timing retard to .7 or .8 per pound of boost
-scale for your injectors
-scale for fuel pressure
-remove a little fuel in the first three columns on the low cam table. I usually do 3%, 2%, 1% moving left to right
-remove or disable any sensors you want
-set vtec and revlimits
boom your done. Probably going to be a little rich but it is a base map.
Old Apr 27, 2004 | 06:05 PM
NChatch's Avatar
thanks KJ, this is for a friend, i am still a little new to it so i dont know all the details, im a computer fucktard
owner/operator
Old Apr 27, 2004 | 07:29 PM
KJ's Avatar
KJ
bored at work
you could even start with the p72 bin. On the older versions of uberdata that I've used you need to open a p72 bin and then import a p30 bin but in your case I'd probably just use the p72 bin and mod from there. Same procedure.
