Temp gauge.. not working. . fan also .
What should I check? I jump the fuse and the fan does come on but doesnt come on by itself? I have replaced the fan relay and still doesnt come on. Please help me.
iam stumped.
Originally posted by Vapor
is your thermostat opening? If it's stuck closed, that would explain why the fans aren't working.
and also your temp gauge is controlled by the single wire plug and sensor going into the side of the head below the distributor. if had quite a few go bad on me
i am going to go with a stupid answer: check the fuse as well
if you can only race me in a straight line then whats the point
...91 SMF SCCA
...91 SMF SCCAhttp://www.flickr.com/photos/8341770@N07/5601083432/http://www.flickr.com/photos/8341770@N07/5601083432/ by http://www.flickr.com/people/8341770@N07/, on Flickr
– the late Tom Thrash SCCA Solo E Production
Guest
Posts: n/a
4l50 3|\|g1|\|35 d0 |\|07 0p3|2473 45 3ff1c13|\|7ly \^/h3|\| 7h3y h4v3 c0ld \^/473|2 73mp5. K33p1|\|g \^/473|2 73mp b37\^/33|\| 160-180 41d5 1|\| 3v3|\| c0mbu5710|\|. |2u|\||\|1|\|g 7h3 3|\|g1|\|3 c0ld3|2 15 b4d 0|\| m4|\|y c0u|\|75, 7h3 m057 |\|071c4bl3 b31|\|g g45 m1l34g3.
Gl4d 70 533 y0u|2 p|20bl3m \^/45 4|\| 345y f1><
