Finally a problem I can't solve...
Old Apr 22, 2004 | 03:24 PM
InsaneCivicCoupe's Avatar
Retired Ricer...
Question Finally a problem I can't solve...
So I am checking on my leaking oil return line today to make sure it hasnt gotten worse, and I notice another oily puddle under my car, but this one toward the back of the motor... I think to myself hmmmm, I wonder what that is... So, I investigate and my first suspect was the transmission, suspicion confirmed, it's tranny fluid.... It seems to be leaking onto the passenger side cv joint which causes it to spray onto my transmission, firewall, crossmember, sway bar, basically everything in the general area.... I just replaced the seal on the half shaft because I had this problem on the other side and now,this side.. I'm stumped... I fix one side and a couple days later, the other sides messed up.... What the hell could it be??? I checked to see if the cv joint was in all the way, and it seems to be fine... is it possible i just overfilled the new tranny and this is excess???Is there another seal on the passenger side that could be messed up??? Is my CV joint messed up??? WTF man!!!! someone help me...
Project WHIPLASH has begun!!!
InductionPerformance.com
NS Racing (813)842-5517
Old Apr 22, 2004 | 03:41 PM
qitstrn's Avatar
Can you spot me 20 cars?
sounds like you have a bad bearing in your tranny. When you pull the axles look inside the tranny and see if the bearing is ate up. I had that problem once before.
Old Apr 22, 2004 | 03:43 PM
Retired Ricer...
damn man, its a brand new tranny and it feels and sounds so smooth.... about how much would that cost to fix if thats the problem, and is there anything else it could be???
Old Apr 22, 2004 | 03:46 PM
qitstrn's Avatar
if thats the problem the bearings are $50 a piece. One for each side. Did you get the tranny new or used? You say it's a new tranny
Old Apr 22, 2004 | 04:13 PM
Retired Ricer...
well i bought it used just meant its new to me.... i think the tranny had pretty low miles... i dont blame the seller at all because after driving it for almost a week now, it just started doing this, and like i said there are zero grinds, its clean, and very smooth.... i think its just bad luck/timing....
Old Apr 22, 2004 | 06:51 PM
NChatch's Avatar
i stepped on my weiner!
i just think it is the seal bro, they pinched pretty easilly. it happens all the time.
Top Dead Center Performance
Mobile Alabama 251 661 6067
owner/operator
www.tdcperformance.net
Old Apr 22, 2004 | 07:04 PM
na200whp's Avatar
Powered by BOOST
make sure the vent is not blocked . causes psi to build in the trans
K series on crack
Street Car on 25PSI V V V V V V
http://www.youtube.com/watch?v=_sn1WsbI0UQ
S D M
Old Apr 22, 2004 | 07:16 PM
cochese's Avatar
Chucking up the Dueces
uh oh
Induction Performance.com
PTC torque converter
Aerospace Components
ProFab Performance
R.I automotive
C.R.T transmisions
5.13@145mph
Old Apr 22, 2004 | 08:09 PM
Retired Ricer...
Mike, if you can please let me know what seal you are talkin about, im gonna start checkin every possible problem tomorrow.... hit me on the 2 way whenever... 161*152446*1
na, what vent and where??? never heard of or seen a vent on a tranny.... any help is appreciated....
and yes Adam, uh oh is right, despite the fact that my car is fucked up my dumb hard headed ass couldnt resist the temptation to run a 3 way with a Camaro and a Mustang on the interstate, I won but now for some reason theres oil all over the back of my car, and tranny fluid all in the engine bay... Oh well, they started it....
Old Apr 22, 2004 | 11:28 PM
Retired Ricer...
???? ttt ????
