Leaking Coolant!
Old Apr 21, 2004 | 04:55 AM
JimmyHat's Avatar
Sphincter Say's What?
Default Leaking Coolant!
Heres my delema. the other day I went out to get in my car (95 Honda Civic DX with a D15 in it) and there was a slow leak of coolant leaking out, but the car started fine and runs perfect but there is just a slow leak from the drivers side down arround behind the balancer. heres the kicker there is no water or coolant in the oil? Im thinking this might be a faulty water pump? if this is the case How in the hell do you replace it. I got as far as removing the belts and removing the valve cover along with the first 1/4 of the timming cover but im having one hell of a time trying to get the balancer bolt to come loose on the crank. is the thred a reverse thred for hondas or what? (righty loosie, lefty tighty?). Please help! need to get back into my gas sipper as my V8 is sucking the life out of my pockets.
Old Apr 21, 2004 | 06:07 AM
chi town brat's Avatar
! Ne shab'rud'ni !
if you are thinking it is your water pump, get underneath the car and look for coolant stains on your oil pan. if the water pump is going bad it will start coming out the seep hole on the pump and will stream down.
otherwise carefully check your hoses. sometimes a leak is very small but due to the pressure going thru the engine it comes out looking like a larger leak than it really is making the crack in the hose hard to find.
Old Apr 21, 2004 | 09:17 AM
dropcivic's Avatar
Redneck Proud
could be your water pipe o-rings too. No the crank bolt is not reverse threaded but is abitch to get off without airtools.
Honda certified Tech
Southern Pride not racism
Old Apr 21, 2004 | 09:26 AM
JimmyHat's Avatar
my nuckels are screaming and the bolt wont budge! the leak is a stream down the block but its hard to se, im pretty confident that it is not a hose as the hoses are on the other side on the block. it leaks on the outside of the block so its not leaking from internaly.??
Old Apr 21, 2004 | 02:18 PM
sone's Avatar
pressure test the coolant system, so you could see exactly where it is come from....
Old Apr 21, 2004 | 02:35 PM
JimmyHat's Avatar
and you do that how?
Old Apr 21, 2004 | 04:27 PM
dropcivic's Avatar
Redneck Proud
my impact gun uses 500 ft lbs in reverse so sometimes the bolts needs blasted a couple times.
Old Apr 21, 2004 | 05:41 PM
dr3d's Avatar
"The Hand"
They sell a kit that you use for pressure testing. it plug on top of the radiator and it has a hand pump. you should be able to get one at an auto parts store. Napa or discount
Old Apr 21, 2004 | 10:44 PM
crix's Avatar
:mugen member:
HEY its the water pump I can test it 4 u or
fix it 4 $150 waterpump & timingbelt & labor
LMK....U SEE MY ##
Old Apr 22, 2004 | 04:36 AM
JimmyHat's Avatar
Scott.. how long do you think it would take? The car is already in my garage dissassembled, im putting a new front end on it, so its not driveable.
