Help with H22A1 codes
Old Apr 20, 2004 | 08:13 AM
Jake1234588's Avatar
A.T.F.
Default Help with H22A1 codes
Have a H22A1 in a 96 Accord and its trowing a few codes i wanted to know if anyone can tell me what codes thay were
17
21
43
and mabey give me a lil insite into why the vtec wont kick on,it trew the vtec code because i unplugged it but i plug it in and it still do work,help if you can,thanks alot
Jake
2006 8.0L Up Armored Suburban
2000 Integra LS
Old Apr 20, 2004 | 08:29 AM
cochese's Avatar
Chucking up the Dueces
1 O2A - Oxygen sensor #1
2 O2B - Oxygen sensor #2
3 MAP - manifold absolute pressure sensor
4 CKP - crank position sensor
5 MAP - manifold absolute pressure sensor
6 ECT - water temperature sensor
7 TPS - throttle position sensor
8 TDC - top dead centre sensor
9 CYP - cylinder sensor
10 IAT - intake air temperature sensor
12 EGR - exhaust gas recirculation lift valve
13 BARO - atmospheric pressure sensor
14 IAC (EACV) - idle air control valve
15 Ignition output signal
16 Fuel injectors
17 VSS - speed sensor
19 Automatic transmission lockup control valve
20 Electrical load detector
21 VTEC spool solenoid valve
22 VTEC pressure valve
23 Knock sensor
30 Automatic transmission A signal
31 Automatic transmission B signal
36 traction control found on JDM ecu's
41 Primary oxygen sensor heater
43 Fuel supply system
45 Fuel system too rich or lean
48 LAF - lean air fuel sensor
54 CKF - crank fluctuation sensor
58 TDC sensor #2
61 Primary oxygen sensor
63 Secondary oxygen sensor
65 Secondary oxygen sensor heater
71 random misfire cylinder 1
72 random misfire cylinder 2
73 random misfire cylinder 3
74 random misfire cylinder 4
hope this helps
Induction Performance.com
PTC torque converter
Aerospace Components
ProFab Performance
R.I automotive
C.R.T transmisions
5.13@145mph
Old Apr 20, 2004 | 01:11 PM
mtber's Avatar
http://www.phearable.net/tech/mil/troublecodes.html
