car idle at 200rpm...
Originally posted by KJ
If the rivets that hold the tps on have not been replaced or slotted it will not be your tps out of adjustment. They don't go out of adjustment unless you remove the rivets. You tapped into the tps signal wire for the zex kit right? What kind of connector did you use? If you used the one that pinches into the wire you may have cut some of the strands and messing up the signal.
If all els fails and everything is running good otherwise just turn the idle up with the adjuster screw.
