valves
Old Apr 17, 2004 | 08:54 AM
nipple69's Avatar
Default valves
how do check too see if vavles are bent or worn out
Old Apr 17, 2004 | 09:01 AM
99B16Si's Avatar
machine shop can presure test to see if theyre sealing when shut but to see if theyre bent i think u have to check the length
Old Apr 17, 2004 | 10:16 AM
skunk2eg's Avatar
I miss my cx motor
run a compression test to see if any of the cylinders are noticably low. it could POSSIBLY be bent valves
the only visual way to tell is to take off the head from the block
***!! will pay $$$ for: Black GSR leather front seats and a 92-95 hatch black cargo cover !!***
Old Apr 17, 2004 | 12:29 PM
KJ's Avatar
KJ
bored at work
Compression test. If you get low numbers on any cylinders do a leak down test.
Old Apr 17, 2004 | 02:04 PM
nipple69's Avatar
the head is off the car
Old Apr 18, 2004 | 07:58 PM
na200whp's Avatar
Powered by BOOST
if you can get a valve out you can put it in a drill and see if it appears to wobble. this is will not show if valve is just slighly bent. or you can pour coolant into the intake and exhaust ports and see if cooant leaks past the valves.
K series on crack
Street Car on 25PSI V V V V V V
http://www.youtube.com/watch?v=_sn1WsbI0UQ
S D M
Old Apr 18, 2004 | 08:29 PM
crix's Avatar
:mugen member:
I FIXED it today (bad injector)
