head pressure?
Old Apr 16, 2004 | 10:56 PM
ÖcIvIcChK's Avatar
conspicuous consumption
Default head pressure?
when i turn on my ac the fan doesnt turn on and after a few minutes the engine seems like its choking. someone told me it might be out of freon but that was fine so i checked the pressure and it was like 420 lbs. what the hell could that be?
Boosted Baby..
Another Usless Deutsch Invention
Old Apr 16, 2004 | 11:04 PM
Vito_Corleone's Avatar
TR Balla Donor Supreme
Are you saying you get no cold air? And that your engine bogs when you turn the air on? And where the hell did you "check the pressure"?
Old Apr 16, 2004 | 11:16 PM
ÖcIvIcChK's Avatar
or maybe the fan motor? could be 'stuck' or burnt out?
Boosted Baby..
Old Apr 17, 2004 | 11:08 AM
ÖcIvIcChK's Avatar
right next to where you check the freon above the radiator
Boosted Baby..
Old Apr 17, 2004 | 02:57 PM
dropcivic's Avatar
Redneck Proud
420? sounds like it could be a bad expansion valve.
Honda certified Tech
Southern Pride not racism
Old Apr 19, 2004 | 07:25 AM
na200whp's Avatar
Powered by BOOST
with no a/c condenser fan the high side head pressure will go sky high. the engine will have trouble turning the compresser at those psi and engine speed will drop. try hitting the fan motor and see if it starts to spin. if so the brushes in the motor are bad and it will need to be replaced.if it doesnt spin then see if it is getting power may be a blown fuse or open wire. normal high side psi should be around 150 - 185 depending on outside temp.
K series on crack
Street Car on 25PSI V V V V V V
http://www.youtube.com/watch?v=_sn1WsbI0UQ
S D M
Old Apr 19, 2004 | 05:33 PM
ÖcIvIcChK's Avatar
thanks
Boosted Baby..
