ctr pistons in 96 gsr?
Old Apr 16, 2004 | 10:32 PM
Dave6699's Avatar
Default ctr pistons in 96 gsr?
buddy of mine is offering me his ctr pistons, i was wondering if its worth my time and what would i be lookin at in power increase??
Dave
Old Apr 16, 2004 | 10:47 PM
mtber's Avatar
Your compression is now about 10.6:1
Ctr pistons would put you at 12.0:1
You will gain power by upping your compression but, your cams & valve train are going to limit the power you make.
Installing these pistons would call for:
Block Honing & Piston pressing.
New main & rod bearings (to be safe)
Pilot bearings for your crank
Possibly new oil & water pumps (to be safe)
New timing belt
New headgasket
Possibly new headstuds
Oil pan gasket
Seals & Orings (oil pump oring seal etc)
Then after your bottom end is done, I would highly recommend upgrading your valvesprings & cams. While you do that you should install a new set of valve seals
The list goes on.
Old Apr 16, 2004 | 11:02 PM
Vito_Corleone's Avatar
TR Balla Donor Supreme
If you're going NA these or p30s are the pistons to run, but it gets pricey as mtber pointed out. As he said, you'll also want a supporting head with all that compression.
