Rear main oil seal ?'s
Old Apr 16, 2004 | 09:30 AM
keuball's Avatar
sutef bwen
Question Rear main oil seal ?'s
i've got a 98 civic HX
there has been oil leaking, and all signs are pointing to the rear main oil seal leaking.....
1. Can smell oil burning.
2. Clutch has been slipping
3. Carbon build up around the bell housing.
was told to check the dist. o-ring.... it loox fine
haven't checked the flywheel inspection cover for oil on the flywheel....
ok to the point.... i am planing on changing out the rear main oil seal this sunday...
has anyone done this before and can offer any advice?
does anyone think that this is a misdiagnosis on my part, in blaming the rear main oil seal on the leak?
Old Apr 16, 2004 | 12:15 PM
keuball's Avatar
sutef bwen
any advice will help....
thanx in advance
http://www.REFLEXsounds.com
Old Apr 16, 2004 | 12:51 PM
99B16Si's Avatar
replacing a rear main seal is a big pain in the ass, make sure thats the problem first. the only was to tell is to clean the area near the bell housing and trace it back to inside the tranny casing
Old Apr 16, 2004 | 01:18 PM
keuball's Avatar
sutef bwen
can you think of any other seals that could leak, and cause the carbon build up aroung the bell housing?
Old Apr 16, 2004 | 01:48 PM
NitrousAcid069's Avatar
4.6L Rice Eater
most likely...its the main seal...i had to replace it on my ex, it was a big pain in the ass but hey...it was worth the money i saved in labor if i would have went to a shop....
Old Apr 16, 2004 | 01:57 PM
keuball's Avatar
sutef bwen
r there any special tools needed, or does it just pop right in?
Old Apr 17, 2004 | 08:04 AM
4.6L Rice Eater
its really just changing a gasket...you will need gasket sealer...but that about all...the hardest thing is seperating the transmission from the engine, if you can do that...your good to go.
Old Apr 17, 2004 | 12:33 PM
KJ's Avatar
KJ
bored at work
Well are you leaking engine oil or tranny oil. If the leak is real bad and you don't notice your engine oil low it might be the left side drive shaft seal. Best bet if you are not sure is jsut to replace the drive shaft seals also when you do the rear main.
Old Apr 17, 2004 | 03:00 PM
dropcivic's Avatar
Redneck Proud
rear mains are easy. Replace your clutch while you are back there. Just take a small mallet and tap the seal in.
Honda certified Tech
Southern Pride not racism
Old Apr 18, 2004 | 03:07 PM
keuball's Avatar
sutef bwen
thanx to all for advice..... change over went very smooth
