which clutch
Old Apr 9, 2004 | 09:03 PM
compleks delsol's Avatar
Catch My Drift?
Default which clutch
ok i got a 93 del sol si with a sohc zc swap using the 93 transmission what kind of clutch disc do i buy like for what car
Old Apr 9, 2004 | 09:12 PM
mtber's Avatar
You buy the clutch disc for the tranny you have.
I believe you are running a sohc hydro tranny, hence you buy a clutch for a 93 civic ex etc.. Check out clutchcityonline.com
The best way to figure out what tranny you are running is to check the tranny code & compare it to a transmission chart via google.com
Old Apr 9, 2004 | 09:17 PM
Catch My Drift?
thanks alot
Old Apr 10, 2004 | 02:26 AM
Catch My Drift?
ok that helped somewhat the 93 si trans is that the same as the older si trans ie 1990 everyone is telling me use 89 dx clutch on the si tranny so it will fit on the zc block but you are telling me to use the si clutch lmk somthin if anyone has had this prob
Old Apr 10, 2004 | 05:30 AM
Catch My Drift?
Ttt
