clutch question
just installed a ys1 cable tranny and new clutch assembly and have been breaking in the clutch for the last 2 weeks.
im drivin down the road and POP as im shifting clutch pedal goes to floor & cannot engage in gear . . . was convinced as i was coasting into a parking lot that the clutch cable snapped BUT . . it looks fine, clutch pedal has no pressure. . . anythoughts?
Take it apart & see what happend
yeah, just lookn for some thoughts, will share when i figure out.
Something similar happened to my friend saturday night, The clutch just went out on him a few weeks after his clutch job. Turned out there is a plate on or around the transmisson (Sorry I'm tired) that holds the clutch cable at a certain position, Like the throttle cable. Make sure you have both bolts in and they are tight. He couldn't line it up properly when he did the clutch job, so he only had one bolt in, and it just spun loose after time, and the plate slid down, and the clutch wouldn't disengage.
NO NO i beat it is your CLUTCH PEDALsupport thay rust so easy and the weld brakes get a flash light and look up under the dash and see if it is still 2gether
i love AUTOZONE
i love AUTOZONE
