coilover squeaks.. HELP lol
Old Apr 9, 2004 | 06:46 AM
Jaso0on's Avatar
Is now ballin!
Default coilover squeaks.. HELP lol
k i got a 93 lude, and i jus put on coilovers and now when i slow down and hit a bump even at low speeds it squeaks and its very very annoying, there was a little bag of rubber circle things that i think i shoulda put in, but i SUCK with suspension work as u guys can tell lol.. so lemme know if anyone can help!
RIP Kevin (Slo_Si) Gonzalez - 09/13/2006
Old Apr 9, 2004 | 07:13 AM
pressuredsol's Avatar
Pleasure the do me
Do not not think the lack of grommets would cause the squeak...but you should have used them.
Old Apr 9, 2004 | 08:21 AM
cochese's Avatar
Chucking up the Dueces
or if they are a cheapo brand name they will make noise
Induction Performance.com
PTC torque converter
Aerospace Components
ProFab Performance
R.I automotive
C.R.T transmisions
5.13@145mph
Old Apr 9, 2004 | 10:05 AM
Jdm Civic's Avatar
Make sure the lower adjustable nut has the lip pointing up, to be between the spring and adjustments. Mine did this until I realized I put the nuts on upside down.
Old Apr 9, 2004 | 12:02 PM
Jaso0on's Avatar
Is now ballin!
u know, i think im gonna jus deal with the problem or pay someone to fix it lol im so damn lazy..
Old Apr 9, 2004 | 01:39 PM
TRD_Tc's Avatar
Using The Force Of N/A
just another victim of cheap coilovers. either way you should have used the rubber piece. good luck.
Old Apr 9, 2004 | 04:21 PM
Jaso0on's Avatar
Is now ballin!
they are not cheap lol they are tein.. lmao
Old Apr 9, 2004 | 04:25 PM
TRD_Tc's Avatar
Helps when you post the brand sometimes. Anyways...try the rubber cap. If that doesn't work then I don't know what to tell you.
Old Apr 9, 2004 | 09:33 PM
mtber's Avatar
improper installation is your answer :-/
missing parts such as rubber peices is not a good thing.
Old Apr 10, 2004 | 11:19 AM
TSX24L's Avatar
Have someone bounce up and down on your car and you look for the noise. Sounds like a bushing to be or around the strut cap area.
