Top piece of my TPS is broken off...Will it be ok?
the tps sensor on top of my intake manifold is still there, but there is 2 spots that you plug in, one on the side, and on on top, the top part is broken off...is that ok??..or should i replace it, i bought the car like this
A tps sensor is located on the throttle body inbetween your firewall and your throttle body. It is not ontop of your intake manifold.
I believe you are talking about your intake air temperature sensor.
If you do not have a check engine light from the broken sensor or a vacume leak, then you should be ok.
There's no TPS sensor on the top of the intake manifold...
Take a pic or find a pic online and circle what the hell you're talking about. Better yet, if you've a check engine light then pull the code to find out what it is.
