axle keeps popping out
Old Apr 4, 2004 | 12:54 PM
integra's Avatar
90% grind 10% sleep
Default axle keeps popping out
My passenger axle keeps popping out for no reason is there something that is saposed to keep it in the tranny? i had to push that shit back in early in the morning today any help from anyone
Honda Valve Adjustments 50$
I TUNE KPRO AND S300
I DO NOT WORK FOR FREE
Originally Posted by THE_ONE
Old Apr 4, 2004 | 12:56 PM
40ozCasualty's Avatar
shift_lock
There is a clip on the axle on the tranny side, Its probably gone bad, I'm not sure if you can replace just the clip. (Its on the axle, and it clips inside of the tranny)
Old Apr 4, 2004 | 03:07 PM
NChatch's Avatar
i stepped on my weiner!
its a snap ring, and from what i have seen they dont come seperately, go back and tell the place you bought it from that your axle didnt come with one and they will give you one from another axle...............
or you have the wrong axle.........this happened to me before from car quest!
Top Dead Center Performance
Mobile Alabama 251 661 6067
owner/operator
www.tdcperformance.net
Old Apr 9, 2004 | 10:17 AM
Jdm Civic's Avatar
Old Apr 9, 2004 | 01:05 PM
crix's Avatar
:mugen member:
check the clip 1st
is the axle new or is it a new problem..If u want help LMK
I Fix the same problem for a friend......
Old Apr 9, 2004 | 03:13 PM
juiced2ndgenteg's Avatar
if its an old axle check the little bit of splines on the end of the axle(after the clip). if they are worn it will cause the axle to spit itself out. this happened to me. it would spit the axle in between shifts. either that or the clip is missing(if the axle is new) also check your engine mounts. the engine could be moving around so much that the axle pops out.
Old Apr 9, 2004 | 04:59 PM
KJ's Avatar
KJ
bored at work
Just use some pliers and spread the clip out a bit. Had to do this a bunch of times with h22a swaps running 90 teg axles.
