crank and bearing ??
Old Apr 4, 2004 | 09:22 AM
Dabwuigwe's Avatar
Digga
Question crank and bearing ??
will a GSR crank work well in an LS block?? i swear i read somewhere it would...... or am i better off with stock??
also about how much is it to have rod bearings replaced??
Old Apr 4, 2004 | 09:33 AM
99B16Si's Avatar
yes a gsr crank will work but youll need gsr rods also. youd be de-stroking the motor from 1834cc to 1797cc and changing the rod/stroke ratio from 1.53 to 1.58. rod bearings generally cost around $80 for a set of 8 give or take 10bucks
Old Apr 4, 2004 | 09:38 AM
Dabwuigwe's Avatar
Digga
so i could not use type r rods for this set up??
Old Apr 4, 2004 | 11:44 AM
mtber's Avatar
You can use type-r rods on a GSR crank or Type-R crank w/ gsr rods etc.
Type-r rods are lighter & more balanced then gsr rods.
You should honestly just run an ls crank & rods, save your self some money & get a true 1.8L displacement.
The difference in Rod to Stroke ratio isnt that much.
Rod bearings are $8-13 each half depending on what dealer you use. Acl bearings are a cheap alternative, but I recommend oem bearings
Old Apr 4, 2004 | 12:47 PM
Dabwuigwe's Avatar
Digga
you guys are PIMPS! thanx for the help....
Old Apr 5, 2004 | 05:11 PM
Vtaaak y0's Avatar
Booyaka
Camp1320 or kteller.com should have acl bearing kits for 100 bucks which include the plastigauge and lubricants.
Old Apr 5, 2004 | 06:06 PM
BitbyStreetRacin's Avatar
once your bit, your done.
Would putting the GSR crankshaft not help in high revving power if not allow his motor to rev just a little bit higher?
Old Apr 5, 2004 | 06:11 PM
KJ's Avatar
KJ
bored at work
yeah sure it would help.
Old Apr 5, 2004 | 07:00 PM
So that reason alone is why I would do it. High Revving pwns
Old Apr 5, 2004 | 08:10 PM
mtber's Avatar
IMO changing your rod & stroke ratio from a 1.54:1 to a 1.58:1 is not worth it unless your motor is going to be seeing 8-10k for long periods of times such as road racing etc.
Read up on rod to stroke ratio:
http://www.honda-tech.com/zerothread?id=714519&page=4
