hollowed cat
Old Apr 3, 2004 | 12:11 PM
13Brotary's Avatar
Default hollowed cat
on my 93' Accord, I had a clogged cat so I hollowed it out, and it made a real crappy tinny sound. to combat that, I put a length of pipe through the cat, so it is essentially a straight pipe. The onyl problem that I have now is that it makes a real bad noise, kind of like the exhaust is leaking. I think that it might be coming from the pipe echoing of the inside wall of the cat. Does anyone know of any ideas to stop this noise without spending any money? To add one more variable to equation, the bolts are almost stripped, and probably won't take a few more loosennigs and tightenings.
Old Apr 3, 2004 | 12:29 PM
Frankie Figs's Avatar
Too Much is ALMOST Enough
just get under there with a saw and cut the cat housing off.
Old Apr 4, 2004 | 10:16 AM
Josh's Avatar
Dr. Doom
get a test pipe, problem solved
Old Apr 4, 2004 | 11:40 AM
mtber's Avatar
To make life easy. Save up $50-100 and take your car to Rainbow muffler or Ice cold air. They will take care of you.
Old Apr 4, 2004 | 07:12 PM
mranlet's Avatar
eats gunpowder
Straight-pipe it!
You've got too many parts in there, keep it simple.
-MR
BTTS, STFU&D
Old Apr 6, 2004 | 08:58 AM
24-7's Avatar
Civic Racing eXperiment
Originally posted by mranlet
Straight-pipe it!
-MR
+1
Old Apr 6, 2004 | 09:22 AM
JamesH's Avatar
I'm just her baby daddy
save money and go to north tampa customs and he will help you out
Old Apr 10, 2004 | 08:19 PM
str33tracer_18's Avatar
straight pipe. cats suck.
