turbo related..waste gate
Old Apr 1, 2004 | 08:15 PM
cochese's Avatar
Chucking up the Dueces
Default turbo related..waste gate
35mm...38mm...40mm...50mm????
is it the more boost the bigger????
Induction Performance.com
PTC torque converter
Aerospace Components
ProFab Performance
R.I automotive
C.R.T transmisions
5.13@145mph
Old Apr 1, 2004 | 08:52 PM
mtber's Avatar
From Tials site:
Flow capacity. Contrary to popular belief, larger higher HP applications do not necessarily require the largest wastegate available. The lower the boost pressure you are gunning for the larger your wastegate needs to be. An engine/turbo combination that is set to 25+psi has a smaller wastegate flow requirement than the same application set to 7 psi. This is because the wastegate is used to lower the boost not raise it, the lower the boost pressure is set the more flow the wastegate must allow.
Old Apr 2, 2004 | 06:40 AM
cochese's Avatar
Originally posted by Vapor
35-38mm is more than sufficient to 450whp
what about 450-550
ProFab Performance
R.I automotive
C.R.T transmisions
5.13@145mph
Old Apr 2, 2004 | 07:41 AM
RyanCivic2000's Avatar
Fuck the DOHC
Originally posted by mtber
From Tials site:
Exactly, except for the fact that you have to add engine displacement and compression into the equation. The more exhaust gas energy you produce the larger the wastegate may need to be.
-00 Civic EX Coupe BUILT D16Y8, Precision SC50, 12.80@105.8 14psi
-00 Chevrolet S10 LS 4.3L V6 Gas Guzzler
http://www.Sohchonda.com
Honda SOHC & D Series Resource
Old Apr 2, 2004 | 09:25 AM
2TurboImports's Avatar
sooo...where's the turbo?
p1v1=p2v2, pressure and volume are inversely related, so it would make sense that a larger wastegate is better for low boost. if you're only boosting 7 psi, then alllll the excess pressure must fly down the wastegate, whereas if you were at 30 psi, there would be less pressure going to the wastegate and more to the engine. right?
Old Apr 3, 2004 | 12:27 PM
Frankie Figs's Avatar
Too Much is ALMOST Enough
since you're doing such a high hp setup you should just get a a 35mm cause you dont need a 40. but if the price isnt much different then i guess it doesn't matter. but im sure money isn't an issue.
Old Apr 6, 2004 | 12:23 PM
SickOfAlltezzas's Avatar
ALUMINUM POLISHER
whats this going in?
Originally Posted by 240Cyanide
TR's better anyways.. where else could you find all this variety of assholes, drug specialist, and pedo's? not on that gay dsm site!
