wheel problems HELP !!!!!!!!!
Old Mar 25, 2004 | 08:00 AM
NikkoRacing's Avatar
harder with words i ain't got time to be breaking my car up even more cause i don't know what the hell im doing im am no kinda mechanic so ill just pay to have someone do replace them
Old Mar 25, 2004 | 09:41 AM
rangcrx's Avatar
engine building &best
ok first you need a 19mm socket take off the tire then Get a 17mm socket undo the 2large bolts Behind the Brake caliper It holds the whole setUp on then get a flat head ((if you have the the 2screws in the rotor undo the)) pull off the rotor your done then pop in the new studs its about a 15min job that will cost you 100bucks if someone else does it.16 if you do it yourself 4bucks each for the studs
i love AUTOZONE
