how to?(rear mount)
Old Mar 24, 2004 | 06:54 PM
Philly Blunt's Avatar
TR Balla Donor Supreme
Default how to?(rear mount)
is it hard to replace the rear mount by the firewall in a 93 civic coupe w/ a b16? mine is bad so i need to do this, please help
Old Mar 24, 2004 | 09:18 PM
mtber's Avatar
If you do not know what you are doing & you do not have the proper tools, pay some one else to do it & watch them.
It can be a pain to get to your rear mount, depending on the day heh
The way I did my rear mount to install my energy suspension kit was:
Put car on jack stands.
Removed wheels for working space...
Removed Header/exhaust manifold to make life easy.
Removed the 2 19mm bolts for the rear lower mount (under the car)
Removed the 17mm bolt that bolts to the mount its self (upper drivers side)
Removed the 17 or 19mm that bolts into the tranny (upper passenger side)
Removed my two lower mounts (front tranny, ac bracket)
Removed/moved the metal rear mount (L shaped)
Removed the old rear lower mount, installed new one with ES motor mount inserts using LONG extensions on a wrachet
Installed ES motor mounts into my two lower mounts.
etc etc etc...
Sounds like fun huh ?
Old Mar 25, 2004 | 03:09 AM
j0shth3j3w's Avatar
Everything is for trade.
I dont think the mount is bad, It doesn't have bottom bolts in it. I ment to get some but I forgot.
Josh
Just text me.... 813-785-5222
Old Mar 25, 2004 | 03:12 AM
j0shth3j3w's Avatar
Jack the car up and look at it you will see what i am talking about. It has a 3 bolts that go in it and the rear mount only has the top one. When I changed the clutch I noticed that there wasn't bolts in the bottom 2 I was going to get some from the junk yard but I couldn't find any. Call Farmer Floydd and see if he has any. Also call me when you get a chance.
Josh
