A ls swap into a 98 dx civic
Old Mar 24, 2004 | 07:08 AM
nismostanza's Avatar
dippin me-rage
Default A ls swap into a 98 dx civic
I need info, where to get a motor, ecu wiring harness and tranny
Old Mar 24, 2004 | 07:11 AM
m0nk3y's Avatar
pwns.
hmotorsonline.com will most likely be the most replied site.
Originally Posted by Lil Ze
Florida is the new Miami through and through.
Old Mar 24, 2004 | 03:07 PM
skunk2eg's Avatar
I miss my cx motor
try to find one locally, ls motors are everywhere
***!! will pay $$$ for: Black GSR leather front seats and a 92-95 hatch black cargo cover !!***
Old Mar 24, 2004 | 05:22 PM
dippin me-rage
thanks guys glad to see everyone is not a cock sucker on TR fuck the haters!
FTB (Fuck The Bullshit, For The Bitches) Member #1
HATERS
FTB 4 LIFE!!!!
(RIP William "Brent" Marshall)
Old Mar 24, 2004 | 09:27 PM
mtber's Avatar
You do not need a wiring harness if you have a 98 civic.
If you currently have a perfect 98 civic wiring harness in your car for your stock motor etc... You will have to rewire your Idle Air Control Valve plug from a 3 plug wire plug to a 2 plug wire plug & you will have to repin your IACV on your ecu from
a14 to a13. A diagram & info is avail on http://phearable.net
You might have to wire vtec sol/vtec oil pressure/knock etc... into your wiring harness if your vehicle is a nonvtec civic & you decide to go w/ a vtec swap.
You also might have to wire Secondary Butterfly Control into your harness if you go with a DOHC gsr swap.
The list goes on, just do research.
Make sure you order a 96-98 swap so you recieve a obd2a ecu so it plugs into your car without a conversion harness.
If you order a 99-00 swap you will have to get a obd2a to obd2b conversion harness & you will probably throw codes because you are lacking obd2b sensors.
If you order a 94-95 swap, you will have to convert your distributor, alternator & injector plugs on your wiring harness to obd1 via using those plugs off an obd1 harness & installing them into your obd2 harness. Fun stuff but it can be done with minor skills. You will also need a obd2a to obd1 conversion harness if you go this route.
Also, you will need
dohc radiator hoses for a civic (99-00 civic si radiator hoses)
99-00 civic rear L motor mount bracket
94-95 DOHC vtec delsol ac bracket to retain your ac compressor.
Old Mar 25, 2004 | 08:35 AM
dippin me-rage
thanks man good info, so if i do a 96-98 ls integra motor swap, i just need what????
HATERS
FTB 4 LIFE!!!!
Old Mar 25, 2004 | 08:04 PM
mtber's Avatar
If you have a 96-98 obd2a ls swap including ecu etc...
All you will need is:
dohc radiator hoses for a civic (99-00 civic si radiator hoses) upper & lower
Integra ls throttle cable.
If you need the swap done by some one, pm me for pricing.
