need solution-stripped timing belt tensioner bolt
Old Mar 23, 2004 | 08:35 PM
NChatch's Avatar
i stepped on my weiner!
Default need solution-stripped timing belt tensioner bolt
hey all i went to put on a new timing belt on my motor and damn i stripped the tensioner bolt anyone know anyone who can fix this real quick or know a good remedy. i just dont want to take all that shit off again, or pull the motor back out...................
Top Dead Center Performance
Mobile Alabama 251 661 6067
owner/operator
www.tdcperformance.net
Old Mar 23, 2004 | 09:26 PM
Vito_Corleone's Avatar
TR Balla Donor Supreme
Try a pipe wrench, they are usually pretty good for taking out stripped bolts, they bite, as opposed to just being there.
Old Mar 24, 2004 | 02:35 AM
TR member's Avatar
if that doesnt work you can take the timing cover off
use a strong pair of vise grips & try to break it loose
or use a 6 point impact socket if the bolts not to f up...
Faster than a speeding ticket
Old Mar 24, 2004 | 02:39 AM
Drivermod03's Avatar
Man I hate them damn bolts Ive stripped out a few of them had to pull the engine and use a special bit to drill them out.
Old Mar 24, 2004 | 03:06 AM
NChatch's Avatar
thats what im worried about,i have an extractor tool (91callowaysi's) that works pretty well. its just in a tight space so i cant get it on all the way.. does anyone know if honda can fix this shit????
owner/operator
Old Mar 24, 2004 | 03:33 AM
j0shth3j3w's Avatar
Everything is for trade.
is this a b or d series? if its b and the tensioner is tight on the belt already use the cams to get the belt on and off. I you have any questions on what I mean call me.
Josh
Just text me.... 813-785-5222
Old Mar 24, 2004 | 04:55 AM
Spyderxl98z24's Avatar
Honda Tech/ Local AssHole
pull it remove it properly ! if you destroy the hole you have to have it fixed ! and that could mean welding or hellicoil or worse ruin an engine over a stupid bolt ! And not be able to use the engine. Aluminum blocks blow for shit like that !
Old Mar 24, 2004 | 06:36 AM
Bill's Avatar
Livin' in Seattle
Well if you're doing a timing belt install than the cover and crank pully should be off anyways. With those out of the way you've got a bit more room to work. I'd go grab a 14mm socket (6pt. and 12pt.) from Sears and see how that handles it. Nine times out of ten the cheap ass sockets you pick up from Auto Zone, Pep Boys, etc. will just round the bolt head where as Craftsman, Snap-On, Matco, etc. will still be able to turn/remove the bolt. If that doesn't work, I'd grab a set of vise-clamps (bolt-specific type) and just put it on the bolt. With the crank pulley out of the way you should have plenty of room to turn a set.
Old Mar 24, 2004 | 08:58 AM
dropcivic's Avatar
Redneck Proud
No we can't fix it at honda. I have seen one tech strip the bolt and we ended up using an air hammer to loosen the bolt.
Honda certified Tech
Southern Pride not racism
Old Mar 24, 2004 | 03:23 PM
sone's Avatar
use an air hammer....that's the only way you are going to get those off...it happen to me a few time already..
