clutch ?
Old Mar 17, 2004 | 09:24 PM
lsrtampa's Avatar
srt4thekids
Default clutch ?
ls/vtec i/h/e/cat/chip/b16tran
my stage 3 ate my flywheel
is the stock b16 fly/clutch going to hold for a while
no launching
Old Mar 17, 2004 | 09:38 PM
Spyderxl98z24's Avatar
Honda Tech/ Local AssHole
wtf do you meanand what are you asking be specific
Old Mar 17, 2004 | 09:44 PM
lsrtampa's Avatar
srt4thekids
is the stock clutch going to work with my setup for long?
Old Mar 17, 2004 | 10:49 PM
mtber's Avatar
A stock clutch for a stock setup like yours will be fine... You could launch it all you want, just learn how to drive & dont ride your clutch disc to death.
Your setup does not require anything more then a beefed up oem clutch like an exedy street strip clutch.
Too many people think they have to use a stage 3 clutch on there cars because it sounds cool.
For $250 you can pickup an exedy clutch kit which handles your setup plus a 75 shot or forced unduction (anything under 300 whp).
Old Mar 18, 2004 | 04:01 AM
+1
Stage 3 clutches eat up oem flywheel they require aluminum flywheels and a Stage 3 puck style clutch is WAY TOO aggressive for the street its a go or no go style clutch. OEM is the best thing in this case, if yo break it in properly it should last you a long while.
Old Mar 18, 2004 | 08:04 AM
lsrtampa's Avatar
srt4thekids
thanks for the reply i was a little scared.
well, at least my left leg will go back to regular size
