isn't this pretty? or at least better
wha'd ya do just take off the vavle cover?..then clean it up? spray the stripper and clean it up again and put it back on?.. or did you just do it all intact, but cover everything up?...nice.
Itz jus' fo deckarayshunz man jus' fo deckarayshunz
Mine is stripped and sanded and ready for polishing
Project WHIPLASH has begun!!!
InductionPerformance.com
NS Racing (813)842-5517
They also have some stuff at home depot called tuff job or something like that it works great I used it on mine when I did it dame results I just havent poliched mine yet!
www.artofspeedproductions.com
yeah the only downfall is, the bare aluminum starts to get a crusty corrosion on it from the humidity and you have to use a plain clean rag and just give it a quick wipe, if you use any other type of rag or cleaner it has a tendency to start to polish up, and then you end up with a mildly polished valvecover......you can clearcoat it and it will look good too
Top Dead Center Performance
Mobile Alabama 251 661 6067
owner/operator
www.tdcperformance.net
owner/operator
