shaving cylinder head
Old Mar 10, 2004 | 09:30 AM
jdmef9's Avatar
Default shaving cylinder head
whats the most i can shave it b4 i have problems. and what does shaving the head exactly mean. will it raise my compression
thanx josh
josh
14.7@91 sohc all motor
Old Mar 10, 2004 | 09:43 AM
jdmef9's Avatar
Default Re: shaving cylinder head
thanx josh
josh
Old Mar 10, 2004 | 07:09 PM
mtber's Avatar
Shaving a cylinder head will increase your compression ratio but it will cause your cam timing to be retarded.
I do not recommend milling a head more then 20 thousands. I have heard of people milling their heads up to 40 thousands etc..
You will need cam gears to compensate for the timing adjustment you will see when you mill your head.
Old Mar 10, 2004 | 08:29 PM
grumpyoldman's Avatar
zephyrhills
Old Mar 10, 2004 | 08:30 PM
zephyrhills
i shaved my gued head 20 thousands and it seemed do me good
Old Mar 11, 2004 | 07:27 PM
crix's Avatar
:mugen member:
Old Mar 11, 2004 | 11:43 PM
rangcrx's Avatar
engine building &best
JUST remeber if you mill your head more then .20 you need to shave your HEad seaters the round cylinders that hold the headgasket inplace for installing
i love AUTOZONE
Old Mar 12, 2004 | 01:38 AM
calloway 91si's Avatar
i shaved my ls head .40 and it ran fine people told me that i would have a problem overheating but i didnt and like mtber said it retards your cam timing so u will need to get cam gears to get it correct and it ran like a champ i
