SOHC VTEC w/NITROUS???
Old Mar 12, 2004 | 08:07 AM
RyanCivic2000's Avatar
Fuck the DOHC
Originally posted by littlehatch
anyone dyno with the spray? what does it put down jw.....
201.1 WHP 210 WTQ
I abandoned this project to go with a turbo because I could not get the desired A/F ratios as you can see. It would have made more like 220whp if the horsepower hadn't dropped off like that due to the way overly rich condition. This was with a D16Y8 and ZEX dry kit.
-00 Civic EX Coupe BUILT D16Y8, Precision SC50, 12.80@105.8 14psi
-00 Chevrolet S10 LS 4.3L V6 Gas Guzzler
http://www.Sohchonda.com
Honda SOHC & D Series Resource
Old Mar 12, 2004 | 02:34 PM
littlehatch's Avatar
Honda
doesnt' zex have a kit activates when your wide open and does the mixture so it's not to lean or rich. i believe i saw them for sale.
stock eg rear seat f/s with no rips. make an offer.
Old Mar 12, 2004 | 03:42 PM
integrakev78's Avatar
(Torqueless Wonder)
I like the zex kit thats how it is supposed to work
Old Mar 12, 2004 | 03:46 PM
(Torqueless Wonder)
Originally posted by RyanCivic2000
I ran a 75 shot on my D16Y8 for more than a year and over 20 bottles with STOCK internals.
What else did you have to do to your car so you wouldn't blow the motor running a 75 on it.
Old Mar 12, 2004 | 08:37 PM
Fuck the DOHC
All you need is a Walbro 255lph high pressure fuel pump, colder spark plugs, and retard ignition 3-4 deg to run a 75 shot.
Old Mar 12, 2004 | 10:57 PM
f22c1's Avatar
do internals, port and polish the head, fuel pump, injectors, plugs and a direct port if u can afford it. then spray the shit out of it! spend a few g's on mods and sleave the block! now that's alot of nitrous!
Old Mar 14, 2004 | 09:11 AM
  #17 (permalink)
Fuck the DOHC
Why would you sleeve the block for just a nitrous setup? Stock sleeves easily hold to around the 400-500whp range.
Old Mar 16, 2004 | 06:50 PM
  #18 (permalink)
NitrousAcid069's Avatar
4.6L Rice Eater
it would be fine, dont run more then 75 on stock internals though...my friend used to have an intake, header, exhaust, and a cam gear w/ a dry zex kit in his sohc vtec civic and rana 15.1 at the track all day...the motor never ran shitty...youll be happy with your results...
Old Mar 16, 2004 | 09:05 PM
  #19 (permalink)
mtber's Avatar
Walbro 255 is overkill for a sohc on nitrous.
Without a GOOD fuel pressure regulator the walbro 255 will not allow you to regulate your fuel pressure to a sohc level in my experience...
I recommend a factory fuel pump with a b&m fuel pressure regulator or aem fuel pressure regulator.
I also recommend a WET kit with a set of plugs that can handle nitrous such as ngk7 series plugs. The reason being is I personally like wet kits better TO each is own.
Retarding your timing depends on how much you plan on spraying. The nitrous kit will probably recommend 2-4 deg of timing retardation.
Stock internals will be fine up to a 75 shot.
I personally wouldnt run more then a 55 dry shot on my daily driven sohc without putting it on a dyno.
I highly recommend taking your vehicle to a dyno to safely spray a 75 shot on a sohc.
Old Mar 16, 2004 | 09:22 PM
  #20 (permalink)
(Torqueless Wonder)
I just blew my motor two days ago running a 65 shot on a b18b1
