aem fpr inline/offset
Old Mar 7, 2004 | 04:54 PM
kender's Avatar
gadget man
Default aem fpr inline/offset
I have seen the aem fuel pressure regulator for the b16 ( 94-97 vtex delsol and 99 si ) with either offset or inline soted in the description. what I want to know is what is this refering to and is there a preference when putting this on for a turbo.
U.S.S.A Crew Member #001
Old Mar 7, 2004 | 05:04 PM
mtber's Avatar
A fuel pressure riser or regulator is a module that baisically adjusts your WOT fuel pressure.
For forced induction applications you need an FMU.
Old Mar 7, 2004 | 05:34 PM
kender's Avatar
gadget man
I will be running hondata and they require a 1:1 rising rate fpr ( thus the aem fpr ) what I am wondering is the diff between offset and inline.
Old Mar 7, 2004 | 06:42 PM
mtber's Avatar
Here ya go:
http://www.aempower.com/product_fuel.asp
One sits in line one sits on the fuel rail....
Old Mar 8, 2004 | 08:57 AM
NChatch's Avatar
i stepped on my weiner!
i dont suggest an fmu, they really put alot of stress on your fuel pump, if have a good pump then you dont need your present one to be pumping at max rate, when you go into boost....think about it 12:1 12psi for every one pund of boost so 10 psi of boost equals 120psi of fuel pressure, most stock pumps max out at around 70-80, and then bleed off excess............i say get a nice pump and use the AEM. also fmu's go bad and you dont know it and cause your car to idle fatt as shit and run really rich
Top Dead Center Performance
Mobile Alabama 251 661 6067
owner/operator
www.tdcperformance.net
