Noise on my Engine
Noise on my honda 4 door. My step-father thinks it sounds like a bearing but he doesn't know much on foreign cars. Was wondering if someone could help me out.
A spun bearing/rod knocking sounds the same on all piston engines. If you are talking about a tapping it very well may be the valves, that's a commong Honda thing. Describe what you're talking about a little bit more thouroughly.
dude i told ya it was the bearings, but i dunno....the kinda sound of loose marbels, but not loud, kinda like what it would sound like in a fome cup i guess.
Itz jus' fo deckarayshunz man jus' fo deckarayshunz
Originally posted by Cronic
Unless the knock is VERY bad, you don't usually hear it at Idle.
However...
Does the noise sound deep, or shallow in the motor? Is it a light tapping sound in the head, or is it a deep knocking sound in the block?
However...
is the sound high or low
growning noise ?
metal tapping ?
loose marbles sounds like valvetrain or oil pump
