14b turbo on 88 crx si
Old Feb 27, 2004 | 02:33 AM
importeclipsegst's Avatar
Default 14b turbo on 88 crx si
has anyone built a home made turbo kit using a 14b 1g eclipse turbo on a 1988 crx si? I was told that the wastegate acuator wont clear the block??? is this true? if so whats the best way to deal with this? should i die grind some of the block to make way for the wastegate? or is there a way to extend the exhaust bolts and make some sort of spacer for the exhaust manifold?
thanxs
Old Feb 27, 2004 | 03:32 AM
F4A22's Avatar
Old School
I have done those kits several times.I bent the actuator so it would clear and didnt have a prob.I have everything u will need to pretty much build a kit.If u need help installing it or need parts pm me.Best bang for the buck and good luck.
Old Feb 28, 2004 | 02:28 AM
the only thing i am missing is the oil line to feed the turbo, i didnt know whether to use a high pressure rubber hose, hard line, or flex line, if uknow where i can get one that would be very helpful
EM1 Crew Member #3 !!!
2000 FBP
Si
Old Feb 28, 2004 | 05:35 AM
F4A22's Avatar
Old School
Get a braided one to handle pressure.Street Performance(571-0500)sells them at a reasonable price.He also has all the fitting u need to install it.
Old Feb 28, 2004 | 06:28 AM
Walter's Avatar
Im as loyal as my options
www.homemadeturbo.com will help you out
blah blah blah
