Ne Points.....on vafc different than S-afc???
Old Feb 26, 2004 | 02:25 PM
NChatch's Avatar
i stepped on my weiner!
Default Ne Points.....on vafc different than S-afc???
why when i try to set up my NE points for fuel adjustment i cant set them up likei did my old safc??
i use to use
1000
2000
3000
4000
5000
6000
7000
8000
nowi have to use something like
1000
2200
3900
4900
5500
6100
and so on................... how come i can just run them in sequential rpms thousanths??????
Top Dead Center Performance
Mobile Alabama 251 661 6067
owner/operator
www.tdcperformance.net
Old Feb 26, 2004 | 04:56 PM
NChatch's Avatar
i guess im retarded or this question is??
owner/operator
Old Feb 27, 2004 | 08:17 AM
NChatch's Avatar
i dont know either vapor, i figured soone like you would know. i tried to set it up, in consecutive 1000 rpm increments like my safc was and it just wont let me do it, its weird. i dont understand it.. i just want to go from 1000-8000 .
owner/operator
Old Feb 27, 2004 | 08:41 AM
Y2JAY's Avatar
do u have the old 1 or the new 1
Old Feb 27, 2004 | 11:23 AM
NChatch's Avatar
just the normal VAFC, not the II
owner/operator
NChatch's Avatar
the NE points still stay the same, but when i go into low or high throttle its the adjustability from rom to rpm that gives me a problem
owner/operator
Old Feb 29, 2004 | 05:41 AM
import jedi's Avatar
mike just go in and under etc. you will find initialize hit yes then turn the key off.this will reset the unit and your ne points will be at 1000,2000 3000 and so on.but you have reset all your setting
hopr this helps,larry
